1960 parking brake - NCRS Discussion Boards
1960 parking brake
  • John M.
    • January 1, 1999
    • 1553
    1960 parking brake
    Can anyone tell me how to remove the chrome T handle from the parking brake handle on my 60? The shaft of my handle is starting to corrode and I would like to polish and replate the shaft but cannot figure how to remove the pin that holds the T handle to the shaft. The pin appears to be simply a driven in pin but does not have access from the top side to drive it out.Was this not intended to be removed or was this originally a setscrew and has been bastardized by a previous owner?
  • Mark S. Lovejoy
    Re: 1960 parking brake
    I can't help with the removal procedure, but I can tell you my '58 is attached the same way. It looks like a blind hole with a pin driven in flush. How good are you at drilling very small holes? You MAY be able to do so on a Bridgeport, I don't think I would try it on a drill press.
    • Doug Flaten
      I drilled out a roll pin on the steering head lock of my '58 Harley last year. I only had access from the one side and there was not clearance to get a drill into it. I bought one of those flexible drive shafts for my Dremel tool and used a small diamond or tungstun impregnated bit or tip that ground the pin away. The flex-drive has a small head allowing you to get access and the tip that I used did not grab and stick or break off like most small drill bits do. May be worth a try.
