What is the original finish on the Positraction Metal Tag on the rear differential of my 63'? I'm being told natural, painted, or red dye.
1963 Posi Metal Tag
Posi plastic(?) tag
Mine disappeared or disintegrated years ago, but to the best of my recollection is was red and made out of plastic. It resided between the filler plug and the carrier, but I don't think it acted a a sealing washer because I believe the plug threads are tapered. My AIM (Sect G81 sheet1 ) supports this recollection. The part number is 3825109.
Duke- Top
Re: 1963 Posi Metal Tag
I believe that they are natural. They're perfectly round, unlike the triangular red plastic tags on later cars.. Chuck1963 Corvette Conv. 327/360 NCRS Top Flight
1956 Chevy Sedan. 350/4 Speed Hot Rod- Top
Re: 1963 Posi Metal Tag Not round
Chuck and Dave (sounds like a part of a Beatles tune) are not totally correct. The tag is metal and looks very much like the 62 and earlier ones. The 63 is round but one side is cut straight as to fit into the space. (Picture the red plastic ones) Finish is original. Hope this helps! Phil #8063- Top
Phil is 100% correct. It isn't a perfect circle. One side is flat. Chuck1963 Corvette Conv. 327/360 NCRS Top Flight
