I am considering mounting my 2X4 WCFB setup (2626S/2627S) on the 350 that I run in my '57. (The 283 block is put away for safekeeping.) I have seen info that the WCFB's should not have a fuel pressure exceeding about 4.5 psi to operate properly. My question is (1) anyone have experience running this setup with a stock 70's era fuel pump? (2) anyone know if I can mount a 57 fuel pump on the 350 to achieve a proper fuel pressure? (3) any other things to watch for?
David B.
David B.
