1968-69 Distributor Clamps - NCRS Discussion Boards
  • Everett Ogilvie
    Re: 1968-69 Distributor Clamps
    Yes, I am aware that it was a distributor exchange for K66.
    I agree that the case for the stamped steel part looks strong. The '68-'69 TIM does not mention the distributor hold down. I can't recall the exact line item on current judging sheets - if the line item is for the distributor only, or if it mentions the clamp.
    • Mark F.
      • January 1, 2003
      • 139
      My August 5, 1968 built car has the stamped clamp.
      Mark Franken
      • Dick W.
        • 10483
        The current sheets mention the distributor only. Good point on the clamps. This is one of the items that needs to be researched for the next revision of the manual
        Dick Whittington
          • 43193
          Dick-----
          For 1969 I think we can say with virtual certainty that the stamped steel distributor clamp was used across-the-board.
          1968 is the year of uncertainty. From the little bit of information we have with this impromptu survey, it looks like early engines got the "wire" type and later got the stamped steel. Just when the changeover occurred for big blocks and small blocks would need to be further researched.
          • Jim B.
            • July 31, 2002
            • 146
            My Original owner 68 L79 has a stamped steel hold down. Build date July 17, 1968.
            Jim Boudreaux
            Jim Boudreaux
            LA Chapter, NCRS
            _____________________________
            1968 British Green Convertible 327/350HP Original Owner
            2002 Z06 Black on Black Original Owner
            2007 Z06 Velocity Yellow w/Black/Titainium Original Owner
