actuator 71 - NCRS Discussion Boards
actuator 71
  • lyndon sharpton
    actuator 71
    how do I test the actuator are where should I put the vacuum on the back side of the actuator? an if is is leaking is most likely the rod seal?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: actuator 71
    Test both sides independantly. Each actuator has two chambers.
