wipers 68 vette - NCRS Discussion Boards
wipers 68 vette
  • James A. Lloyd Jr.
    wipers 68 vette
    new wiper motor, new wiper switch at dash , wiring seems to check out ok , still wipers will not work , vac. opens wiper panel when overide used.,
  • Mark F.
    • January 1, 2003
    • 139
    Re: wipers 68 vette
    Make sure the wiper switch on the dash is grounded properly. If not, it will not work. Had that happen to me one time after I took the dash apart.
    Mark Franken
    • Mike Baker
      Re: wipers 68 vette
      You've probably already checked the "limit" switch mounted near the wiper motor that prevents the wiper motor from starting before the wiper door is open but, I'll mention it anyway.
      Good luck
      • Stephen W.
        • March 1, 2002
        • 301
        Re: wipers 68 vette
        This sounds dumb but I went crazy with my 71 on a rainy day trying to figure out why they didn't work. Then for some reason I turned the knob under the dash and they worked again!
        • Mike Baker
          • Bryan M.
            • April 1, 1999
            • 386
            Re: wipers 68 vette
            Yes, make sure the override switch is turned to the right and grounded. This completes the wiper motor circut to ground. I used a ring lug placed around my override switch and then routed it to a good ground point behind the kick panel.
            Here is a 68 wiper motor wiring diagram.
            • Bryan M.
              • April 1, 1999
              • 386
              Re: wipers 68 vette
              And while we are at it. That infamous clicking sound that is described when the battery is connected and disconnected due to a battery drain. This is sometimes caused by the wiper tach solenoid engaging when circut number 8 has a malfunctioning wiper gear relay in the wiper motor. Notice the circut comes straight from the battery.
