C2 Carpet Underlayment/Heat Barrier - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    I'm installing the Al Knoch heat barrier that I purchased for my 66 roadster. The barrier is jute covered with a roofing paper like rubber or vinyl top layer. I was told that this pretty much replicates the original underlayment. Included in the kit is a small piece that fits on top of the transmission tunnel from the firewall to under the radio and radio console. I didn't notice any underlayment here when I stripped the old carpeting. Installing this under the radio would make the radio even more difficult to remove and I'm inclined not to install it or cut it back to in front of the radio. I could see where a heat barrier here could be beneficial. Comments are appreciated.
    Dave Kitch
    33108
  • Scott S.
    • February 1, 2002
    • 62
    Re: C2 Carpet Underlayment/Heat Barrier
    Dave, I just purchased from Corvetee Central, part # 132007, which is console insulation "underdash/center console". I didn't have any in mine when I got it. I've yet to recieve part so I couldn't tell you how thick, etc.
    • Stephen L.
      • May 31, 1984
      • 3148
      The underlayment on the tunnel ahead of the radio should be there and its the same material that is under the carpeting. Refer to your AIM for details etc.
      It was not glued in place but rather just laying there for 30+ years.....
      • Mike M.
        • May 31, 1974
        • 8365
        agree with steve. all my 66's had the piece under the radio. i'd put the repo's in. mike
        • Dave K.
          • November 1, 1999
          • 951
          Since it might interfere with radio removal, I'll probably lay it in and not cement it down. If I need to pull the radio, than I can pull the insulation out. You won't see it on the trans tunnel once the radio panels and shift console plate are on.
          Dave Kitch
          • Mike M.
            • May 31, 1974
            • 8365
            dave: i have an original here in the shop and there is no evidence of contact cememnt or any other adhesive on the underside. regards, mike
