I recently found a trailer hitch for a 68 to 73. The part that goes on the differental is missing. Would anybody have a drawing of the part with the size descriptions?
C3 trailer hitch
Re: C3 trailer hitch
its two pieces, each fab'd out of 1/4" steel . the two pieces utilize the four bolts securing the spring to the diff. cover. there's an additional 1/4" piece welded to the pair of spring retainers. then a bolt traverses the welded pieces and the hitch. it'd be an easy piece to fabricate. mike- Top
In 1969 I put a trailor hitch on my 1964 convertible like the one you have described for the 68-73. I installed a trailor hitch on my 1970 in 1972 that was different. This one connected to the rear frame crossmember with two locations and two more locations at the inside rear bumpers. Real easy hitch to remove and replace when needed.- Top
