I have a question regarding my speedometer. The speed no longer seems to register above 30MPH unless I'm doing say 60 where it might say 50MPH. It seems to bounce especially at lower speeds on deacceleration. It also seems to be getting noisy.
Could this be the cable or speedo and is the fix as easy as replacing the cable or will this require other parts at the level of the tranny such as the gear seal w/ o-ring? Several catalogs list more than one length of AC repacement cable ie 70, 71 or 72 1/2 inches -- which length is correct?
Lastly do you have to drop the speedo/tach panel or can the cable come off the rear of the speedo with patience and working your hands from under?
Any input or tips would be appreciated. I hate jobs like this as replacing a blown bulb behind a tach on my 72 took better than an hour.
