C1: Distributor and generator maintenance - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12695
    Hi all,
    To lubricate the distributor and generator do I just have to squeeze some 10W40 into the lubrication pipe/hole (with the cap on it)? How often should I perform this task?
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C1: Distributor and generator maintenance
    one drop yearly. don't overfill. mike
    • Chris H.
      • April 30, 1990
      • 817
      If you do overfill expect lots of nice clean oil around the generator area in a nice pattern:) (hood, etc.)
      Chris
      • John M.
        • January 1, 1999
        • 1553
        Rob,
        Almost every generator out there has been converted to sealed bearings years ago. Putting oil in one of these will just cause oil to run into your generator.
        Someday, when you are bored and don't have anything else to do, pull your end plates off you generator and see if they are open or sealed bearings. If they are open, then pop the couple of bucks for new, sealed bearings (available at any bearing house", and never have to worry about that generator again.
        Regards, John McGraw
        • Chris S.
          • January 1, 2000
          • 1064
          John is right
          Esp the ones remaned by some of the resto companies use sealed brgs
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
          • Clare Carpenter
            Does Pirkle use sealed bearings?
            I recall that he does but can't say for sure. He rebuilt mine but I haven't "fired" it up yet.
            • Chris S.
              • January 1, 2000
              • 1064
              Yes
              John does use sealed bearings
              He includes a note in the box - not to oil the cups
              What I was trying to say without plugging vendors.
              (he does nice work by the way )
