Crossfire Inj.-Rough running engine - NCRS Discussion Boards
  • Monte Schimmer
    Re: Crossfire rough running
    Ok, here's what I have found out so far. I had one bad plug but when I replaced it, it didn't help the problem. I can't find any vacuum leaks.
    Now for the interesting part. When I unplug the left injector, the engine will idle smooth and runs around 2000 RPM and I don't have a check engine light. When I plug the left injector in and unplug the right injector, the engine will idle a little rough and I have the check engine light. When I plug both injectors in, the engine will not idle, but will run rough at higher rpm's.
    Any other ideas out there what my problem is ??
    Monte
