What takes place in a 1959 powerglide transmission - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    when you kickdown the throttle and it shifts to low gear? What makes it go into low gear? Thanks, Jimmy
  • Bob R.
    • June 30, 2002
    • 1595
    Re: What takes place in a 1959 powerglide transmis
    There is a linkage running from the carburator to the transmission. When you kick down on the accelerator it mechanically downshifts the transmission.
    • Roy B.
      • February 1, 1975
      • 7044
      To adjust correctly pull the gas pedal rod back wide open , then adjust the kick down rod to just "fit"connect to the Carb linkage.. It's now set like factory for passing gear (downshift).To make passing come on later or sooner you ether lengthen or shorten the kick down rod .
      Note:just letting you know, that at any speed , if you put the trans. in to reverse the trans will go to reverse and lock up the rear wheels ( like putting on the emergency brake) Nice to know if your in a panic!
      • Jimmy J.
        • May 31, 1988
        • 304
        Roy, Will it hurt the transmission to put it in reverse in a panic? Thanks, Jimmy
          Yes, it will Won't do the U-joints any good either.
          • Roy B.
            • February 1, 1975
            • 7044
            Dropping it in reverse in an early Chevy PG cast iron is easy because reverse is down on the shifter , where later GM reversed it to up. My kids a couple of times hit the shifter in our 55 and 56 Chevy years ago so I know it works.
            Stopping the drive shaft with the trans at speed isn't advised , but is quicker then pulling on the emergence brake when your heading at a tree if your brakes go out.
            My wife once did it in our 56 when it's brakes went out going down a hill, she remembered what I told her to do if it ever happened , " thank God" ( and never hurt the trans)
            You can only do this to a Cast Iron PG , later trans won't do it!
            • Verle R.
              • March 1, 1989
              • 1163
              At age 16 I was "racing" my dad's new 57 powerpack Chevy hardtop. I accidentally pulled it into reverse at 50 or 60 MPH. It got me home but a few days later was in the Chevrolet dealer getting a new powerglide installed.
              I didn't often get to drive it alone after that.
              Verle
              • Roy B.
                • February 1, 1975
                • 7044
                Re: "verle" did it stop you *NM*
                • Verle R.
                  • March 1, 1989
                  • 1163
                  Roy,
                  As you indicated earlier, it locked up the rear wheels, causing the car to slow dramaticly.
                  I was just pointing out that damage to the transmission is possible. That may be insignificant if you succeed in avoiding a collision.
                  Verle
