C-3 Fan clutch - NCRS Discussion Boards
C-3 Fan clutch
  • D S.
    • March 1, 2005
    • 1551
    C-3 Fan clutch
    Can fan clutches be restored? What is the correct one for 1970 454 with AC? 1972?
    Scott
    Re: C-3 Fan clutch
    Scott-----
    First of all, fan clutches can be restored. Fred Oliva of Vintage Automotive Research performs this service. If I recall correctly, his e-mail address is foliva@net.gate.
    The original fan clutch was GM #3937771. I'm not sure if that was an Eaton or Sweitzer clutch. In any event, it was discontinued many years ago and replaced by the GM #3916141 which may still be available from GM. The 3916141 is an Eaton-manufactured clutch.
    For 1972, a different fan clutch was used. That clutch was GM #3991426. This was kind of an "odd-ball" looking fan clutch. It was a Sweitzer-manufactured clutch with the "bi-metallic" thermostat. That part was like all other Sweitzer-manufactured fan clutches. However, this one had a large "dish-like" perimeter around the finned center section. This fan clutch was discontinued many years ago without supercession. However, the GM #460742 can be used to replace it. That fan clutch was also discontinued within the last year, or so, and replaced by the GM #88961763. I don't know what the configuration is of the latter clutch, but it would be a 100% functional replacement for all 1971-73 Corvettes, regardless of engine.
    • Pat K.
      • November 1, 2003
      • 351
      Re: C-3 Fan clutch
      Scott,
      If you decide to use Fred, be prepared to wait a LONG time. I'm 7+ months already.
      Pat
