I am lost as to the cause of the problems I am having with this engine. It will not start now. It began having problems last weekend. It was running well until it stopped running at a stop light. It restarted and ran OK for about three miles and quit again. It restarted an ran for about 6-8 miles and began running rough with lack of power and rough idle. I limped home and left it until this weekend. Today in the garage it ran roughly for a few minutes then quit and won't restart. Seems to not have spark.
The car is NCRS correct except for 3721 AFB which is the replacement carb for the original 3269S. Carb was just rebuilt by reputable carb shop here in St Louis. Now for other details. Battery new, tests at 12.6 volts. Coil is new. New 4656 fuel pump. Gas tank was cleaned and resealed with Eastwood kit. Fuel filter is stock. Stock dual point distributor. Dwell set recently and checked at 33 when the engine ran today. Timing checked at 12 degrees. Voltage at coil checked at 12 volts and at 6.7 volts through resistor. Spark plug wires are new reproduction wires with about 10 hours run time. Distributor cap, rotor and points are in excellent shape with about 10 hours run time. Engine is in good shape mechanically with good compression. Cam is stock Duntov 098.
Engine cranks fine but no fire. I put a teaspoon or so of gas directly into the carb tried to start and still no fire. Totally non responsive.
What else can I check. I have volt and Ohmeter but am not sure how to futher diagnose this problem. I at first suspected fuel starvation but now it seems there is no spark.
Need help. It is one of those nice 70 degree days made for Corvettes and I am stuck in the garage.
