Is there a proportioning valve in the C1 brake system? If so where is it located? Thanks, Jimmy
C1 Brakes
Re: C1 Brakes
Jimmy-----
There is NO proportioning valve in a C1 brake system. The only 1953-82 Corvettes that ever used a brake system proportioning valve were as follows:
66-68 Corvettes with J-56 HD brakes (adjustable type valve)
78-82 Corvettes (fixed rate valve combined with distribution block/pressure differential sensing switch).
That's it.In Appreciation of John Hinckley- Top
