C2 trip odometer bracket - NCRS Discussion Boards
  • Richard Weddle
    Hello, most knowledgeable corvette restorers. My 1966 corvette is missing the bracket under the steering column that holds the trip odometer cable. I have located this bracket from a 1963, and wonder if it's compatible. thanks.
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: C2 trip odometer bracket
    In a 67 the trip cable is attached thru the steering column support bracket. No additional bracket required. Check your AIM as its possibly the same...
    • Mark S. Lovejoy
      Same for '65, AIM section UPC 9 sht 4, p/n 3839153 support assembly.
      • Randy S.
        • January 1, 2003
        • 586
        Richard....
        65 and 66 Telescoping columns used a separate bracket under the column to attach the odometer reset cable. Not sure what you have with a 63 bracket?
        Non tele column 63 bracket is different from 64-66 bracket according to Long Island Corvette catalog
        Randy
