Thinnest rear T arm shims?? - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    My 67 seems to go from just about zero toe to a tad too much toe by moving the thinnest shim currently installed from one side to the other. The shims are from a stainless kit that came with 1/4", 1/8", and 1/32" shims. Are they any shims thinner than 1/32"? Is it normal to have to resort to shims so thin to get the alignment right?
    Re: Thinnest rear T arm shims??
    Tim-----
    The thinnest shim available from GM is 1/64" thick. I don't know if the stainless shims are available in this thickness, or not.
    • Terry F.
      • September 30, 1992
      • 2061
      When they start getting that thin, I would make my own. Just a thought. Terry
        • 15610
        Swapping a shim from one side of the trailing arm to the other should change toe measured at the tire crown by less than 1/32" and you want each side to be in the range of zero to 1/32". Refining the toe by using a 1/64" shim is good if you can find one.
