C1 turn signal flashers - NCRS Discussion Boards
  • Bernard M.
    • August 31, 1994
    • 341
    There are currently some 1956 & 1957 dated Tung-Sol turn signal flashers on Ebay (see link). The part number, manufacturer's name and date information on them are in black paint or ink. I have one NOS 1957 dated flasher in a GM box and about 20 1954 NOS Tung-Sol flashers individualy boxed in a case marked with the same date. All the information on each of these is impressed in the metal, not painted or ink stamped. I thought the black printed style was a later innovation and dated examples this early should have the markings impressed in the metal like those I have. I'd be interested in purchasing one of the 1956 flashers on Ebay if I thought it was correct (I'd probably have to compete with ten others on this board now that I've informed the marketplace that they're available). Can someone enlighten me?
    1957 Tung-Sol flasher on Ebay
  • James F.
    • December 1, 1985
    • 596
    Re: C1 turn signal flashers
    Benard, Original '56 flasher was Signal-Stat. It was a small blockish rectangular shape, not round.It was clipped to the dash support and located right beside he ingition switch terminals. Believe the '57's were mounted to hed ash support which ran from dash to firewall per the AIM. These flashers may have been round, . egards,
    • Bernard M.
      • August 31, 1994
      • 341
      Jim, Thanks for the response. Can you expound? Were they metal or plastic. How were they marked (if at all) and were they dated?
      • Roy B.
        • February 1, 1975
        • 7044
        JIM wasn't the 55 or 57 long cad embossed # two tangs Never had a 56
        • James F.
          • December 1, 1985
          • 596
          Re: C1 turn signal flashers-Bernard, oy
          '56 Flasher,
          signal-Stat, 1.25 long, .75 wide, 9/16"high,excluding the two tangs.Top cap is aluminum staked to a thin Bakelite ottom.Two tamgs also staked to bottom. Top cap has engraved: Signal-Stat
          ZN 232-12V
          Flasher
          Dash lower support channel has a "U" clip to the pass side of the ignition switch terminals. The flasher is forced into the "U" and secured. egards,
          • Bernard M.
            • August 31, 1994
            • 341
            Thanks Jim *NM*
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12695
              Here it is:
              Rob.
              NCRS Software Developer
              • Bernard M.
                • August 31, 1994
                • 341
                Good photo Rob. Do you have one of the '56 bracket you could share? Regards, Bernie
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12695
                  Hi Bernie,
                  My car is a '59-er but which bracket do you refer to since it isn't attached with a bracket in my car...
                  greetings,
                  Rob.
                  Rob.
