Big Block oil pressure drop - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    if the pickup is too close to the bottom of the
    pan the same thing will happen. should be about 3/8" from the pan bottom. use modeling clay to check the distance by putting the clay on the pickup and install the pan,remove the pan and check the tickness of the clay. you can do this without the gasket just add the gasket thickness to your reading
