C2 Anti-Theft Suggestions - NCRS Discussion Boards
  • Kent S.
    • July 31, 2004
    • 5
    I'm looking for recommendations for alarm systems and other methods/ideas on protecting a C2 from theft.Thanks for your responses. #42277
    Re: C2 Anti-Theft Suggestions
    If the pros want it, they'll get it; best fallback position is a good Agreed Value insurance policy.
    • William V.
      • December 1, 1988
      • 399
      I agree with john. If a pro wants your car the battery will be disconected and the midyear will be flatbedded. no alarm system will help.
      • Gary Fickeisen
        Kent,
        Insurance of course. Also anything that can slow down a thief will help. Try a gas shut off, battery disconnect, second hidden battery for alarm system, and a ignition disconnect switch. When traveling, over night, cover and park where you can view your car, and if possible block in with another vehicle. Also I believe there is a tracking system that can be installed, maybe someone else has information on that.
        Regards.
        Gary
        • Eugene B.
          • May 31, 1988
          • 710
          Kent,
          You may want to read about a security system called Viper. The link to the website is: http://directed.com/security/viper/default.asp
          Out of the ones I've seen, it looks great to me. Allows GPS tracking of your beauty.
          Good luck,
          Gene
          • Gary J.
            • April 1, 1980
            • 1229
            Re: Anti-Thef Suggestions
            Try a big logging chain with a bullet proof lock and can also attached a big dog to it. I have seen the logging chain in use before.
            Gary Jaynes
            #3503
            • Brian M.
              • February 1, 1997
              • 1837
              I leave an empty holster on the seat.
                Try this - it worked for The Rev
                • Roy B.
                  • February 1, 1975
                  • 7044
                  If some one REALY wont it , they WILL get it. All the locks put on a house front door (DA) just brake a window and go in.
