SHIFT BOOT '66 - NCRS Discussion Boards
SHIFT BOOT '66
  • Marc N.
    • August 31, 1998
    • 97
    SHIFT BOOT '66
    how do you change the rubber boot inside the square around the 4 speed.....???thanks
  • Bill Clupper
    Re: SHIFT BOOT '66
    Pull the console, then you'll see a metal plate that holds the boot down. Remove the shifter ball and reverse lockout tee if you haven't already, unscret the plate, pull up the old boot, put the new one on reassemble and you're home free
