ORIGINAL RADIATOR ???? - NCRS Discussion Boards
  • Doug J.
    • April 1, 2005
    • 140
    ON AN ORIGINAL COPPER RADIATOR FOR A 1972 CORVETTE WITH A 454 AND A 4 SPEED WITHOUT AIR, WAS THERE A RADIATOR CAP ON THE RADIATOR ITSELF OR WAS THERE JUST AN OVERFLOW HOSE GOING FROM A SMALL PIPE AT THE UPPER RIGHT HAND CORNER OF THE RADIATOR TO THE EXPANSION TANK WHICH HAD THE CAP. THANKS IN ADVANCE, DOUG
  • lyndon sharpton
    Re: ORIGINAL RADIATOR ????
    it would have a aluminum expansion tank on 72 LS-5 with out air with the cap on the tank the cap was a RC-26
      Doug-----
      ALL 1969-72 Corvette big blocks used a radiator with an external supply tank and NO radiator filler provisions on the radiator, itself. The radiators used for 69-72 big blocks were copper/brass, except for 1969 L-88/ZL-1 with manual transmission and 71 ZR-2 with manual transmission which used aluminum radiators.
