1967 Master Cylinder Rebuild - NCRS Discussion Boards
  • Rodney Armstrong
    I am looking to have the my original master cylinder rebuilt to original specifications. Does anyone know who provides this service?
  • Brian M.
    • February 1, 1997
    • 1837
    Re: 1967 Master Cylinder Rebuild
    White Post. Fastest turn around in the hobby. WWW.whitepost.com
    • Scott Marzahl
      I used Apple Hydraulics, (your other main source for this) and they did an excellent job with a few day turn around. I think they were a few bucks cheaper than White Post.
      • Brian M.
        • February 1, 1997
        • 1837
        I believe that Apple used a stainless sleeve and White Post uses a Brass sleeve. White Post also coats it with a black DOT 4 safe coating. Beautiful work.
        • Scott Marzahl
          Apple will use either a SS or brass sleeve, however they recommend Brass.
          • William O.
            • April 30, 2001
            • 355
            Whitepost is flawless, you won't be disappointed.
            Good luck.
