1959 Brakes
  • Jimmy J.
    • June 1, 1988
    • 303
    #1
    1959 Brakes
    Where can I find a good picture or drawing of the front and rear brakes shoes, and hardware installed on a 1959? Thank in advance Jimmy
    • 42936
    Re: 1959 Brakes
    Jimmy-----
    You can find what you seek in early editions of the Chevrolet Parts & Accessories Catalog. Unfortunately, those aren't so easy to find and they're certainly NOT inexpensive when you do.
    • Dave Suesz
      What are you trying to learn? *NM*
      • Jimmy J.
        • June 1, 1988
        • 303
        Re: What are you trying to learn?
        Dave, I am trying to determine if I have something set up wrong in my front brakes. If I get down on the pedal hard they may pull left or right however if I just press the pedal firm and slow it does not pull. The brakes are adjusted according to the corvette service manual. Everything in the two front and rear brakes is new. Thanks, Jimmy
        • Roy B.
          • February 1, 1975
          • 7044
          Back in the ooold days we arcked the brake lining to match the drums (sanded them on a machine) . To day you cant do that , they out law'ed the machine that did it, so now brake shoes don't hit the drum %100 ( high spots) not even contact.
          • Dave Suesz
            As usual, the gummint locked the door AFTER
            the horse escaped.
            Cam grinders were used to re-arch the new lining to match the actual curve of the re-cut drum, instead of just the standard curve, which meant the break-in on new brakes was about 2 minutes. Naturally, the grinder would fill the air with asbestos dust, not a good plan. However, modern brake linings have yet to me declared the dust of satan, so the machines, not around today, would be nice to have for classic car shops. Alas.
            • Dave Suesz
              By "new", you mean
              new cylinders, shoes, springs, and hoses? Old, constricted hoses might do what you describe. Un- broken -in shoes might, too.
              • Rob Dame
                Re: As usual, the gummint locked the door AFTER
                I found one a few years ago. It's out in the shed if you know anyone who wants one
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: ROB, the gummint locked the door AFTER
                  If your talking the brake pad sander
                  • Rob Dame
                    Yes Roy the old type brake shoe contourer.
