C1 water pump leaks - NCRS Discussion Boards
C1 water pump leaks
  • Larry P.
    • June 30, 1999
    • 481
    C1 water pump leaks
    I can't get my water pump gaskets to stop leaking. After I jack the motor up and get the bolts started real good, my logic was to let it down so the weight is where it will be and then tighten. Should I tighten all the bolts and then let it take the weight or should it matter. My last attempt has the water streaming out the top left bolt hole.
    LP
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 water pump leaks
    Tighten them before leting it down
      Larry -
      Are both sides of the engine mount bracket smooth and free of any pits in the gasket area? Use fresh gaskets (two on each side of the pump) with a film of sealer on both sides of both gaskets, and use thread sealer on the bolts.
      It's easier to load and secure the "sandwich" if you use two threaded studs, one at the top hole on each side, load the "sandwich" of parts over the studs, install the two lower bolts, then remove the studs and replace them with the upper bolts; prevents wiping sealer off the gaskets or damaging them while you're trying to manipulate all the parts and get the bolts started.
      • Bernard M.
        • August 31, 1994
        • 341
        Larry,
        Be sure to use thread sealant on the bolts. Three of the four pass through into the water jacket and may leak unless sealant is used.
        Regards, Bernie
        • Larry P.
          • June 30, 1999
          • 481
          Is the Permatex sealer ok to use on the threads or do I need something else?
          LP
          • Larry P.
            • June 30, 1999
            • 481
            John,
            Should I use two gaskets at all locations, 8 gaskets?
            LP
            • Bernard M.
              • August 31, 1994
              • 341
              Larry,
              I use the high temperature thread sealant made by Permatex. It comes in a small tube.
              Bernie
                Nope - four gaskets - one on each side of the engine mount bracket (two on LH side, two on RH side).
                • Rob Dame
                  I don't know if you are using repro bolts but it seems like i remember hearing that some of the repro bolts are too long and will not tighten up.
