Closed chamber heads turned into open chambers? - NCRS Discussion Boards
  • Steve Antonucci
    Hi everyone,
    While surfing the "bay", I came accross this item:
    1967 L88 or L89 392 Chevrolet Corvette Aluminum Heads Item number: 4545283145
    These are a set of 1967 aluminum big block closed chamber heads that were opened
    up to an open chamber-like configuration. I was always told that this was
    not possible due to thin wall section in and around the combustion chambers.
    Are these one of those "better left alone" type of performance parts?
    Still, I'd like to know from you past big block racing types if this is even
    a do-able modification, or playing with fire.
    Steve
  • Mark #28455
    anything can be done with aluminum
    If properly done, either they only opened the chamber part of the way (about half way to open chamber size) to miss the water jacket, or they opened it as much as needed and then welded the chamber to produce a new wall. How do you as a buyer know if the part will hold up to usage? You don't. Any time you buy hot rodded parts, you take a gamble. For my money, I would wait to find unmodified parts (they show up on e-bay often enough). If you really want the best performing heads do it right and get a set of the d-port heads (077 castings).
    Good luck,
    Mark
    • Steve Antonucci
      Re: anything can be done with aluminum
      Hi Mark,
      You're spot on. I agree and I did purchase a set of '077 heads a while ago
      based on input from several members on this forum.
      These heads in question just caught my eye. Everything I ever read about trying
      to open the chambers up on BBC heads indicated that it was risky at best.
      I actually didn't consider that the chambers would be opened up, then welded to
      form a new wall. Cooling would be my paramount concern with that scenario.
      The number of bids threw me for a loop and I just wanted to be sure that these
      weren't some trick, rarely seen setup, due to modification costs.
      Steve
      • Mark #28455
        racing vs street use
        Most of these severely modified heads were used in the 70's and 80's for drag racing. I remember Lee Shepherd (of Reher Morrison fame) used the 842 castings rather than the 074 castings but would literally lay down MILES of heli arc bead to totally "re-cast" the entire chamber and ports. This was back when better heads weren't available (for "stock" type racing). Now, there's little reason to use old parts when anyone can get the current technology for less than $2000 a pair.
        Mark
        • Steve Antonucci
          Re: Closed chamber heads turned into open chambers
          Hey everyone,
          Those modified aluminum heads are up to $1,500.00 and climbing with 5 days
          left. I still don't get the attraction to these heads.
          Steve
          • Mark #28455
            just another L88 or L89 on the way! *NM*
