1967 427/390 holley 3811 carb - NCRS Discussion Boards
  • Michael C.
    • January 1, 2000
    • 39
    I have a 3811 carb. The GM part number is 3906633-EQ. Does that number have any significant meaning ?? The carb is dated 751 which I know is 1967 May 1st week. My car is a June build 1967 car that I am trying to make as correct as possible. Thanks for any help in advance. Mike Chase
  • Gerard F.
    • June 30, 2004
    • 3803
    The Perfect Carb for your car if
    the EQ is actually EO and you have a standard transmission w/o AIR (EO is for a 427/390 Corvette or a 396/375 Camaro). Metering block number should be 4796 and the fuel bowls have non-externally adjustible floats. The date code of 751 is the latest I've seen (hoping someone will disagree) in Holley carbs for 1967. I'm working on restoration of a 3810 751 right now as a replacement for a June 29, 1967 327/300 (VIN 22049). The carb has the same finish as your brake booster and I can give you some advice on refinishing it. What's your VIN, it most be close to mine.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    • Michael C.
      • January 1, 2000
      • 39
      Re: The Perfect Carb for your car if
      Jerry , thanks for your help. Are vin numbers are within a few hundred of each other. My car is a little bit earlier. Any tips on restoration of the power brake booster would be nice. thanks again !!! Mike Chase
