Addendum
One other thing that I should have mentioned for those that are interested, the change from the cast iron to the aluminum cover did not occur at the same time as the change from the non-indexed to the indexed worm shaft. My September, 1969-built convertible had a steering box with an aluminum cover, but it had the early style, non-indexed wormshaft. The change to the indexed worm shaft end may have occured before the end of the 1969 model year, though. If so, I'd say that it happened sometime between October and December, 1969.
Also, I have a friend who is also the original owner of his 1969. His car was built in October, 1968. His has the aluminum cover, too. So, if cast iron covers were used on 1969s, then it was likely only for VERY early cars.
