'66 #3367 CHOKE SETTING - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Occasionally, when starting the engine cold with the choke working and set, the engine starts with "way too high" of an idle. It drops to a normal high idle with a kick of the pedal, which I believe means the vacuum break is working properly. Do I need to adjust the high idle cam and/or lever to eliminate the excessively high idle I sometimes get on initial startup?
  • Don 42616
    Re: '66 #3367 CHOKE SETTING
    Rob, I had same problem on my 66.High choke idle untill 1 kick of pedal. I knew I had to adjust the choke high idle but didn't realize how. several of the regulars even sent me a diagram. Need a screw driver to twist the tang away from the choke cam.There is a slot for screwdriver on tang. I'm sure you will get the same help I got. worked perfect. Good Luck, Don
    • Mark G.
      • March 1, 2001
      • 227
      • Rob A.
        • December 1, 1991
        • 2126
        Don,
        So that's what that slot is for....thanks...
        • Rob A.
          • December 1, 1991
          • 2126
          Mark,
          Thanks for the info, I'll go through the steps while it's raining today...
          • Rob A.
            • December 1, 1991
            • 2126
            Don,
            I found the problem. The tang lever with the slot in it was actually catching on the round piece of plastic on the bottom of the plastic choke cam. Bent the tang a little and it works fine now. Thanks again...
            • Don 42616
              1967 3X2 choke adjust?
              Hi Guys, Now I have to figure out how to adjust choke idle on center carb. on a 3X2???????? Don
              • Mark G.
                • March 1, 2001
                • 227
                Re: 1967 3X2 choke adjust?
                Don -
                If it is a Model 2300 try this URL;
                http://www.holley.com/HiOctn/TechSer.../Instruct.html
                The back of the chassis service manuals have the specifations.
                Mark #35760
