As some of you may know, GM has replaced all large journal, small block SERVICE connecting rods with a forged powder metal rod of 10108688. This rod is now the only SERVICE connecting rod available for 1968-96 Corvette small blocks and replaces all earlier rods, including the "pink" rods used for 1969-81 L-46, LT-1, and L-82 . This rod was also used in PRODUCTION from about 1993 to 1996 for LT1 and LT4 engines. It's also used in most current GMPP crate engine assemblies, including the ZZ-4, "Ram Jet" FI, and "Fast Burn" 385 hp. Powder metal rods of a different configuration and part number are also used in all Gen III and Gen IV small blocks (except 2006 Z-06, of course).
For a long time, I've had serious misgivings regarding the powder metal rods. I tend to be "conservative" in my thinking and don't like the idea of "powder metal ANYTHING". Well, after doing a bit of research and checking things out thoroughly, I've come around 180 degrees. I'm convinced that the powder metal rods are THE HOT SETUP. If you're building any STREET small block, these are definitely the way to go. FORGET the old "pink" rods that sell for Big $$$ in USED condition. The powder metal rods are at least 25% better than the "pink" rods in every important parameter of strength and durability. Not only that, they are comparatively inexpensive. You can purchase a set of these things under GM #12495071 and that SET carries a current GM list price of $300.44 and shouldn't be too hard to get for $250, or less.
If you're rebuilding any 1968-96 Corvette small block, it's going to cost you at least 100 bucks to have your old rods reconditioned. So, for about $150 more you can have a BRAND NEW set of rods that are superior to ANYTHING originally used in your engine and capable of supporting 500+ horsepower EASILY. This is a true "no brainer" decision. At least, it would be for me. Now, let's see how many morons pay big dolars for a USED set of "pink" rod on eBay or, better yet, what they'll pay for a set of NOS "pink" rods.
The small journal connecting rods (i.e. pre-68) are not available from GM in any form. However, forged powder metal small journal rods are available in the aftermarket. Also available in the aftermarket are higher stength, cap bolt style forged powder metal rods which are superior to GM "Bowtie" rods.
