1968 427 convert oem rallye wheels??? - NCRS Discussion Boards
  • jeffitz
    who would supply the best rallye wheels for my 68 duntov big block,????
  • mike cobine
    Re: 1968 427 convert oem rallye wheels???
    Chevrolet. Watch the swap meets and eBay for some '68 7 inch Rally wheels. They are out there.
    • Harold #43147
      Ralley
      If you want the correct #'s they will be hard to find as 68 used 7x15 this year only. They went to 8x15 in 69. The 7x15 was brought back in 1970 for Monte Carlo made to 77 these you can find these all most any place.
      • mike cobine
        Re: Ralley
        Actually, they were Rally in the books.
        The 1968 15x7 wheel is stamped AG near the vale stem. One year only, they are a bit rough to find, but are basically only wanted by those with '68s.
        The Monte Carlo 15x7 is the FW stamping and is a different offset. The FW is 3-7/8 inch from the back to the face of the mounting surface. The AG is 3-5/16 inch. This more than half inch difference can mean the FW will rub on some cars on the spring. It is also different on the front and will not accept the Corvette trim ring, as the Monte Carlo trim ring is noticably different.
        The 1969-82 15x8 is 3-9/16 deep and the aluminum 15x8-1/4 is 3-3/4 deep.
