327 , aluminum manifold 3844461, heads 3890462
Based on replies to a recent post, I fashioned a pilot post and placed it in the distributor hole. Then I slid the manifold over the pilot and into position. Very slick, except that I still had the same problem. That is, if the manifold is positioned so that the bolts on one side can be threaded in with fingers, the other side is slightly off center causing the bolts to bind so that with diligent effort only about one thread can be started with fingers. The bolts can be tightened without crossthreading or galling, but it takes some patience and a lot of tapping to keep some of the bolts from binding too much.
I read a thread in the archives discussing manifold alignment, and one solution mentioned was to elongate the holes on one side of the manifold. My question is this: is the "tight bolt" situation I described normal, or should I be considering modifing the holes a bit to relieve some of the bind? (These are the same manifold and heads that were on the car before disassembly)
Steve
Steve
