C1 Powerglide Hole Cover - NCRS Discussion Boards
  • Rick H.
    • January 1, 2000
    • 25
    OK, I finally was able to restore and install the transmission inspection plate for my 1955 powerglide and find that it does not cover the hole that is used to to tighten/loosen the bolts that connect the flywheel to the torque converter. Based on the fact that there is an empty threaded hole neat this area, I suspect that there is supposed to be some kind of hole cover here?
    If so, can any of you tell me what it looks like or where I can get one? Thanks.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Powerglide Hole Cover
    Any 55 up Cast iron V8 PG will have it , hard to describe , it's just a dust cover . E-mail me and I'll send you one
