1965 327/365 vacuum advance - NCRS Discussion Boards
  • Rich Ober
    I have a box stock 1965 327/365HP engine and I'm trying to figure out where the vacuum advance hose is supposed to connect on the stock holley carb. I see a plug in the front metering block on the passenger side. No hook ups on the base plate? So this would be ported? What is correct? Thanks!
  • William C.
    • May 31, 1975
    • 6037
    Re: 1965 327/365 vacuum advance
    It is manifold vacuum, and it comes out the side of the metering block on the pass side, look at the diagram on sheet 4 of the assy manual for an illustration. If you don't have it, email me of the board and I'll send you a copy.
    Bill Clupper #618
    • Joe C.
      • August 31, 1999
      • 4598
      Rich:
      Here is a link to a couple pictures of a stock 1965 327/365 which should help you:
      Please excuse all the dust and dirt..........car is recently back from the paint shop and is eagerly awaiting reassembly and detailing.
      Joe
      Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
      • Mike Barnard Sr No 36249
        Rich
        My original carb is off being rebuilt but as I recall there is a special fitting that goes between the metering block and advance fitting. If you have a Paragon catalog look in there as I believe they give a good description and picture.
        • Rich Ober
          Thanks for all the help!! And the photo's!
          Rich
