'66 SMALL BLOCK EXH MANIF FRENCH LOCKS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The french locks on my exhaust manifolds bend against the ignition shielding during installation. Assuming this is normal, what was the factory's method of dealing with this interference?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Rob...
    ...The bolt locks, with one ear bent, only deal with one hex of one exhaust bolt per application. If you are installing them correctly, they should never come close to being in contact with any other part of your car. If so, we need to talk... Best, Dennis
    • Rob A.
      • December 1, 1991
      • 2126
      Re: Rob...
      Dennis,
      The contact I'm referring to is the curved portion that connects the two holes in the french lock. They hang down in the way of the shielding.
      • Rob A.
        • December 1, 1991
        • 2126
        Re: Rob...
        Found some pictures...looks like the curved part of the french locks is bent outward to clear the ignition shielding. I assume this is what the factory did during assembly. Mine were bent inward.
        • Michael H.
          • January 29, 2008
          • 7477
          Re: Rob...
          Rob,
          Sounds like you figured it out. Yes, the straps had to be moved/bent to install shielding and there was no particular direction as far as correct goes. Some were pushed in at assembly and others were pulled out so either would be correct.
          • Rob A.
            • December 1, 1991
            • 2126
            Re: Rob...
            Thanks, I'm still getting familiar with my small block.
