What is the problem when a C1 Carburetor is - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    leaking fuel into the primary venturis when idling at 500 rpm and how do you fix it. Thanks, Jimmy
  • Jim D.
    • 2882
    Re: What is the problem when a C1 Carburetor is
    Float level too high?
    • Ty T.
      • June 30, 2004
      • 72
      As Jim mentioned, check your float level. Also, while it's apart check the float as it may have a leak. Take it out and rattle it and you can tell if there's fuel in it. Also check the seat and valve that the float controls for a hunk of dirt or rust which keeps the float from shutting off the flow of fuel.
      Ty
      • Clem Z.
        • January 1, 2006
        • 9427
        you may need more timing at idle because you may have the butterflys open too far to get your idle speed
