SMOG pump question. - NCRS Discussion Boards
SMOG pump question.
  • Christopher J. Bunsey
    SMOG pump question.
    I have a 76 L-82 with out a smog pump.....did they ALL come with a smog pump?
    Thanks!
  • Mike M.
    • May 31, 1974
    • 8365
    Re: SMOG pump question.
    by 1966 and 1967, california required smog pumps on some corvettes of 66 and 67. by 68, nearly all, if not all, states required smog systems. c-3's not my area of expertise, but i believe your 76 would have left st louis with smog pump. shouldn't be too hard to find like the 66 and 67 critters. can recall pulling a bunch of them off cars of the 70's and tossing them out for the garbage man. mike
      Are the smog pumps dated? Where could I find an original for my 1976? As usual...Thanks
        Use of A.I.R. varied year by year, engine configuration by engine configuration. Acts like A.I.R. was installed when a given power plant configuration was 'close' to the line on emissions profile and/or law(s) required it. In your case, the answer is spelled out in the Judging Guide:
        "All 1975-77 Corvettes are equipped with an A.I.R. system in St. Louis with the exception of 1975-77 L48 with M-40 Turbo-Hydromatic Transmission."
        • Harmon C.
          • August 31, 1994
          • 3228
          The second edition75-77 TIJG says L-48 auto had no smog pump. All L-82's and all 4 speeds had a smog pump. Lyle
          Lyle
            Bill Hodel in Massillon, Ohio can supply whatever you need, but it will be VERY expen$ive.
              Are these pumps dated?
              • Michael W.
                • April 1, 1997
                • 4290
                Yes, as is the diverter valve. Be prepared to $pend big buck$. Not worth it to me unless you're going to have the car judged.
                • Marc R.
                  • April 1, 2004
                  • 288
                  There's a visor information sleeve for a '69 on eBay just now that's at $380 with days to go. Compared to this, Bill Hodel is dirt cheap, and his merchandise is perfect. I'd call him and get what you need. You'll be completely satisfied with Bill's stuff.
                    Christopher-----
                    Usually, the date will be found on a machined surface of the pump's aluminum housing. It's a very small font, Julian date code that has the last digit of the year and the consecutive day of the year. That is followed by a few other characters indicating pump model and shift.
                    Believe it or not, the pump for your car is still available brand new from GM. It's GM #7817809. It currently GM lists for $339.87. It won't have the correct date, of course, but it should be otherwise virtually identical to the original. And, it will be NEW.
                    That's where the GM parts availability ends, though. The original style diverter valve and, even, subsequent replacements are discontinued. The original style check valves are discontinued. The pump bracket is discontinued and the manifold trees are discontinued.
                    As mentioned, Bill Hodel is a good source for original-style AIR systems and components.
                    • Tom R.
                      • June 30, 1993
                      • 4081
                      Re: A.I.R. Point of Information
                      As emission regs tightened, it got tougher for 4 speeds to get certified with available emission control technology. So more automatics were sold to accompany the "luxury sports car" image but eventually GM had to suspend availability of 4-speeds from the Corvette option list in 1982.
                      Tom Russo
                      78 SA NCRS 5 Star Bowtie
                      78 Pace Car L82 M21
                      00 MY/TR/Conv
                        Does anyone have a contact for Bill Hodel?
                        • Alan T.
                          • May 31, 1992
                          • 87
                          I'm confused by the statement that the '75 L48 automatic did not have a smog pump. I have a very early (first two weeks of production) 75 convertible L48 automatic that has the smog pump. The motor is absolutely original as is the smog pump and diverter valve (it has never been off). Is is certain no 75 L48 automatics had the smog pump?
                          • Tom R.
                            • June 30, 1993
                            • 4081
                            Seems like we've gotten into this controversy before about the 75 model year...first year featuring the catalytic converter. I show all 75s equipped with A.I.R.
                            Tom Russo
                            78 Pace Car L82 M21
                            00 MY/TR/Conv
                            • Marc R.
                              • April 1, 2004
                              • 288
                              Billhodel@aol.com or 330.832.0871 *NM*
