On a 1970 L-46, Does anyone know what the thickness of the cylinder wall is for the rear cylinders? Specifically the thickness of the cylinder wall at the very rear.
I also need to find out what the stroke length is?
If not, do you know where I can find out the specs?
Reason being is I accidentally gouged the cylinder wall (right behind the freeze plug) when trying to remove one of the rear freeze plugs and I need to see if this is going to be an issue.
Im sweating this one out.
Travis
Travis
