i am having trouble to get the headlights to open and close together. i have just had the motors rebuilt and am looking for any advise!!! brad
c2 headlght adjustment
Re: c2 headlght adjustment
Brad,
If a pair of headlights on 63-67 open together, exactly, it's pure luck and not by design. They never opened or closed at exactly the same speed on brand new cars so trying to make them operate at precisely the same speed today is not required unless you want this just for your own personal satisfacton. I don't think there would ever be a point deduction unless there was a substantial difference between the two assy's. If there is a substantial difference in speed, you may want to discuss this with the rebuilder.- Top
Relying on memory here, but isn't there a tension adjusting screw on the headlight motors that controls their rate? I went to a seminar on rebuilding these motors about 10-12 years ago and I know I rebuilt my 66 headlight motors after that.
Gary- Top
Gary,
There is an adjustment screw at the end of the hsng but it's function is only to control armature end play. I suppose it would also adjust the speed, for a short time, but would eventually cause something to wear rapidly and the shaft would then create it's own end play.- Top
Not possible- pure luck
I have spent many many hours with my hands tucked into the (expletive) headlight area trying to do what you are trying to do. I think its an impossible task. You can get them to sychronize in one direction only with the adjusting screws on the wye bracket. Theorectically, if everything was in perfect alignment you should be able to have them sychronize in both directions, but I think you are wasting your time. I have had many hours of frustation, and many bad words said to my 67 baby.
Actually I'm hoping someone who has done it will chime in and tell us how.
Jerry Fuccillo
#42179Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
Brad;
The only solution is to rebuild and lubricate both motors, with their associated pivot shafts, and pivot balls, exactly the same way. Even then, they will probably not cycle at exactly the same rate. Any delta less than 5 seconds would be welcome. I have usually gotten the delta to be less than 3 seconds, consistently, but I cannot tell you why, except that I pay very close attention to detail.
If you want to know the acceptable delta, then refer to the Performance Verification And Operations Guide For 1963-1967.
Joe- Top
