57 Water Pump - NCRS Discussion Boards
57 Water Pump
  • Michael K.
    • August 31, 2004
    • 170
    57 Water Pump
    Is this the correct water pump for a 57 2x4? The "How to Rebuild Your Small Block Chevy" book has a picture of one that looks different for my year. The numbers on mine are: GM 21 37826(8)09(8) (I can't tell if they are a 6,8 or 9). It would be logical to me that the one I have is a replacement for the older version.
    Re: 57 Water Pump
    Mike-----
    The casting number is "3782608" on the pump you have. This pump is not correct for any 1957 Corvette. The pump you need to be "correct" is a casting of GM #3736493.
    I believe that the '608' pump could be used for your application as it's very similar to the '493'. However, it's not the "correct" pump/
