Hello friends, I currently have a 283 block and working on determining a compataable engine setup. I hate to ask stupid questions but here it goes anyhoot. Engine is going in a 61.
Can the 3890462 202/194 double hump heads be used on the 283 (3.875 +.030 bore). These heads were originally used on 302/327/350 engines with a 4" bore (as most of you know). Concerned about valve and piston clearance and valve and cylinder side wall clearance since these have the bigger valves. Using flat top piston.
Camshaft preference is GM #3896929. intake lift of 0.390" and exhaust lift of 0.410" (with 1.5:1 rockers) and intake duration of 319 degrees (195 degrees @ 0.050" lift) and 320 degrees (202 degrees @ 0.050" lift).
What do you think, will it explode or be a solid/RELIABLE street engine?
Leon
Leon
