C2 paint on shock absorber bushings - NCRS Discussion Boards
  • Joe R.
    • March 1, 2002
    • 1356
    I'm about to paint some new Delco shocks for my 67 "shock absorber gray," but I want to make sure I paint them correctly.
    I searched the archives and found some cryptic descriptions of how the paint should appear, so I thought I'd double check before I paint.
    On the REAR shocks, I understand that the lower bushing was not installed at the time the shock was painted, so the rubber bushing should be unpainted (black). I plan to leave the upper bushing unpainted as well, even though one post in the archives said the upper bushing could have gray paint on it.
    On the FRONT shocks, it sounds like the entire lower end should be painted gray, including the rubber bushing and the plate that bolts to the A-arm. The upper bushings, of course, are unpainted.
    So, is the above approach correct? I'd like to get it right the first time.
  • Kent K.
    • December 1, 1982
    • 1139
    Re: C2 paint on shock absorber bushings
    Joe----I seem to recall that no '67 shock absorber bushings received any paint or overspray. There may follow posts from more knowledgeable others.
    Kent #6201
    Kent
    NCM Founder - Member #718
    • Tim G.
      • March 1, 1990
      • 1358
      I just cleaned the shocks from a 29,000 mile '66 yesterday. The rears were painted completly aside from the lower bushings. The fronts were completly painted, bushings and all including the very top of the shaft. It looked like the front shocks were compressed while being painted. These were taken off the car 25 years ago and came with the car.
