If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Jim,
on the 57 seat belt question if I place bolts thru the holes in the driveshaft area is there room to use a washer between driveshaft and the hole, also hole seemed very small do Ijust keep that same size hole and just put a normal lock washer and nut on other side thanks
paul
Paul,
I,ll have to go from memory here (healhwise I best not crawl under my '56. I think I can help though. Yes, I recall the whole in the fiberglass body was small. I might have used a 5/16" BOLT, NOTHING SMALLER.CAN'T RECALL IF THE STEEL BACK UP PLATE WAS TAPPED O NOT. DON'T THINK SO. I DO RECALL LATHE CUTTING DOWN THE BOLT HEAD WIDTH TO GAIN EXTRA CLEARANCE WITH RESPECT TO THE DRIVSHAFT. BOLT HEAD TOWARD THE DRIVESHAFT UP AGAINST THE REINFORCEMENT PLATE YOU WANT TO "MASSAGE" THIS AREA AS THIN AS PRACTICAL YET KEEP STRENGTH IN THE ASSEMBLY FOR IT'S INTENDED JOB (KEEP YOU IN THE CAR). ON THE NUT SIDE WHICH IS ADJACENT TO THE CARPET I USED WASHER, LOCK WASHER OR LOCK NUT. CAN'T RECALL.DO RECALL FIRST TIME USING ASTANDARD WASHER AND NORMAL SIZED (WIDTH) BOLT HEAD INSERTED FROM THE DRIVESHAFT SIDE. THIS ARRANGEMENT THE BOLT HEAD LEFT A SLIGHT MARK ON MY NEWLY PAINTED DRIVESHAFT! OBVIOUSLY NOT ENOUGH CLEAARNACE. HOPE HIS HELPS. REGARDS, JIM
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
