C2 SB Starter Pix?
  • Gordon Peterson #4961
    #1
    C2 SB Starter Pix?
    Hi all -
    Can someone either post or email me pictures of an NOS or correctly restored SB starter for a C2? I'm about to go through my '63 starter, and I'm looking for the correct paint and finish detail. Thanks a lot!
    Pete
  • Tracy C.
    • August 1, 2003
    • 2739
    Re: C2 SB Starter Pix?
    Hi Pete,
    Heres a pic of mine. I can't tell you it's "100% correct" but maybe it will give us a frame of reference to speak to. I'm curous myself how close it is.
    I can't seem to find the part number stampings on the solenoid, but everything else seems to be close to the description in the Judging Manual. If anybody knows where the part numbers should be stamped, I'd appreciate more info.
    thanks,
    tc
    • Harry Sadlock
      TC, looks just like the one I installed yesterday. John Pirkle did the rebuild. Also, there is no number on the solenoid.
      Harry
      • Timothy B.
        • May 1, 1983
        • 5149
        Tracy,
        I have a early 63 starter and the solenoid is stamped 1119910 if I am remembering correctly. I know for sure it is stamped on the top of the solenoid.
          Thanks, Tracy!
          Exactly the kind of thing I'm looking for. Incidentally, the solenoid p/n on mine is lightly stamped on the top of the solenoid case adjacent to a large dent or crimp (not damage). I had to use some steel wool to bring it up.
          My observation of the new starter is that the solenoid case appears to have been painted gloss black. The starter main case appears to be semi-gloss black. The aluminum nose piece looks like it has overspray from the main case - very thinly coated in black. The part of the nose that fits through the bellhousing cover doesn't appear to have been painted.
          Pete
          • Richard Bass
            I have my starter and solenoid out of the car and will send u pictures when I return home early next week. My car is a 67 bb I believe both parts are the original pieces to the car. Pirkle sent me a replacement solenoid but I don`t believe we gonna use it after all. The parts are both black as explained in one of the other responces to your query.
            • Kevin M.
              • November 1, 2000
              • 1271
              Re: C2 SB Starter Pix? *NM*
              • Tracy C.
                • August 1, 2003
                • 2739
                Thanks Pete,
                My solenoid has the crimped areas but no part number. The case looks pretty new so I wonder if it was replaced.
                Harry,
                Do you know if Pirkle replaced your solenoid case?
                • Harry Sadlock
                  TC, It was a complete replacement as I had an aftermarket installed when I purchased the car. As I recall the Solenoid for a 63 could be painted or plated, but in either case the number should be there.
                  Harry
                    Hi Kevin!
                    Thanks for the pic. It's hard to see, but it appears that the aluminum nose piece on yours is like mine, not quite painted, more like oversprayed from the steel main body. Is the area that pokes through the bellhousing cover black or bare aluminum?
                    Pete
                    • Kevin M.
                      • November 1, 2000
                      • 1271
                      Gordon,
                      Here's a wide shot you can see the overspry or lack there of in this picture better. Nothing had been done to the started this is factory finish.
                      Kevin
                        • 42936
                        Kevin-----
                        The starter looks just about the way I would expect as far as painting is concerned. I have several NOS starters [none for sale] and they are all painted pretty much like this one.
