'65 Frame Touch-Up Paint Needed - NCRS Discussion Boards
  • Tim Genovese
    A leaking battery lifted the paint on the frame of my '65. I need a recommendation for a spray paint that will closely resemble the original color and finish.
    Thanks.
  • WayneC
    Re: '65 Frame Touch-Up Paint Needed
    Try http://www.quantaproducts.com
    They sell an asphalt-based frame paint that should be the same as original.
    • mike hom
      Tim: If you are talking about the original asphalt based coating, I know that Quanta sells the same coating that was originally applied at the factory. I believe this is sprayable if you thin it out. I'm sure the folks at Quanta can steer you straight on this or maybe some of the other members can tell of their experience with spraying this material.
