Everytime I pull on my steeringwheel my horn goes off. Any Ideas on how to stop it without disconnecting the horn alltogether?
Horn
Re: Horn
Dave,
I think I know your problem. I had a horn issue too When I was turning the steering wheel to negotiate corners the horn would blow sometimes You need to pull the steering wheel. One of the things you"ll find under the hub is a vinyl or plastic disc. This disc can wear thin over time which can result in the horn blowing. You need to repair or replace the disc.
Wayne- Top
