I am building a 1962 vette and Last month I replaced the glass (well almost the chrome plater sent me back some one elses corners REAL LONG STORY) so tonight I installed the corners and I just cant figure out for the life of me what holds the lower stainless in place.
C1 windsheild lower trim
Re: C1 windsheild lower trim
I'm refering to the steel channel that the glass, gasket, and molding all fit into. The bottom piece into which the T-bolts fit. Yes, I think you will have to disassemble the w/s. If you try to force the molding into the channel with everything else in place, there is a strong possibility of breaking something. Do you have the ST12? There are pretty good assembly directions there, and as I recall there is a cross section diagraqm of the lower channel.- Top
C1 windshield notes
I made some notes when I did mine.
LP- Top
