What is correct for the spindle, natural or orange? I saw a 67 that had orange spindes. The judging guide does mention orange.. Also are the control arms high gloss black? A search shows posts where high gloss black is NOT correct??? More of a slight semi..Thanks, Kurt
C-2 Spindle / A arm color 67
Re: C-2 Spindle / A arm color 67
Kurt, when I was restoring my '67, I discovered that the lower portion of the spindle on each side was orange. It appeared to be "dipped" (as oppposed to sprayed)to about 3"up from the bottom of the spindle. My a-arms are gloss black, but not sure if that's correct.
Don- Top
Yes, Don those are accurate descriptions of the originals.
Because the spindles are dipped, the length of orange can vary.
This was done before machining, so those areas should appear unpainted.
H. a. N. D.- Top
Wonder Why No One Answered Your...
..control arm color question. Thought for sure someone would have info.- Top
