Exhaust manifolds without gaskets - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    Following up a previous thread, (in order to install manifolds without gaskets)if I have the manifolds "skimmed" to true up the faces but don't do the same for the head faces, that assumes that the head faces are true enough. Is this a good assumption?
    Steve
  • Craig S.
    • June 30, 1997
    • 2471
    Re: Exhaust manifolds without gaskets
    Yes - the heads are very stout and would not warp and cause issues....as long as you have smooth mating surfaces for the manifolds.....Craig
    • William C.
      • May 31, 1975
      • 6037
      Torquing the bolts might be a good idea to insure the life of the seal.
      Bill Clupper #618
