67 L-71 tripower linkage - NCRS Discussion Boards
  • Del S.
    • March 1, 1991
    • 83
    Could someone help...Im having difficulty with the new Paragon linkage reaching the back secondary carb. The middle carb is a replacement 4055 carb but I have the original 3660 and they look the same. The end carbs are 3659's . Ive looked at pics from one member ... the linkage looks to have the same shape. Secondly , will the long yellow marked spring work well in the vacumn pods for normal crusing?
  • KELLY THEAKER
    Re: 67 L-71 tripower linkage
    you have a pic , should help! give another good look at the pic youy may have them reversed , the shop manual does give a good amount of facts on the sec, vac springs , they state to use the stock spring can't remember colour and to not clip them, this may have come from a holley book also . These are simple and you should be talking to someone who does this for a living Jerry Luck is one and i don't have his # handy . I apologize for not answering your questions completly , you should be asking duke williams or joe lucia or Jack the master. continue on and learn as you go. The factory manual also has good set-up directions on the sec, linkage.
